Quantise Deformer
Quantise Deformer
Deforms geometry by snapping the positions for each vertex a set grid
This node quantises the positions for each vertex of the mesh, rounding them to the nearest value set be the resolution attribute.
  • Local :
  • World :
Displacement Global override for how much the deformer affects the mesh.
Resolution Change the resolution for the vertex quantisation.
  • Locked To Timecode :
  • Running / Loopable :
