Force Affector
Force Affector
Allows forces to be applied to a physics objects.
This node applies a constant force on physics objects. This is typically used push and pull objects towards or away from the subject.
Amount Strength the affector has on the affected physics objects.
Mode The mode of the affector
  • Directional Force : Apply a constant force in a single direction.
  • Repel : Apply a constant force outwards from the centre point.
  • Attract : Apply a constant force inwards to the centre point.
Dampening Softens the motion applied to the objects to smooth out any erratic motion from the affected physics objects.
Randomness Randomises the force amount per object.
Affected NodesChoose which nodes will be affected by the affector.3D Primitive
Excluded NodesChoose which nodes wont be affected by the affector.3D Primitive
Procedural FalloffInput to use a procedural system to control the falloffProcedural Root
