Speed Tracking Modifier
Calculates speed of movement in an input node.Updated: 15 Sep 2026
Calculates speed of movement in an input node.This node calculates the rate of movement of the source node, connected via the “Tracked Node” input, and outputs it as a value.
| Smoothing | Adjust the amount of smoothing to applied to the output value. |
| Decay | Controls the time between the peak to the sustain level. |
| Max Speed | Set a maximum speed the modifier can read for a value. |
| Operation |
| Restore Values | Toggle whether the values restore to 0. If unchecked, generated values incrementally add to the modifier value. |
| Tracked Node | The node that you want to track the speed of. | Null |
