Collision Mesh
Collision Mesh
Allows rigid bodies to collide with a static mesh.
The Rigid Body Collision Mesh node is used to allow rigid bodies to collide with a static, complex mesh - such as a displaced floor. Collisions with a Collision Mesh node use tests against polygons treated as thin planes. This is less robust than collisions with convex hulls as used when 3D Object or Primitive nodes are set up as static colliders. A high frame rate on the Rigid Body Root is recommended to reduce the chance of bodies falling through. Wherever possible, use a 3D Object or 3D Primitive node as a static rigid body should be used instead.
Advanced TODO
These properties set the visibility of debug items in the viewport.
ObjectsThe 3D objects used for the collision mesh.3D Object nodes
