Distortion Deformer
Distortion Deformer
Deforms geometry based on a distortion function
This node deforms a mesh based on a distortion function, creating noisy and glitchy effects.
  • Local :
  • World :
Noise Scale The amount of noise that is applied to the deformer.
Sine Scale Scale the sine wave used in the deformer.
Distort Y Scale How much the mesh is distorted along the Y axis.
Animation Speed Speed the deformer is animated at.
Mask ImageUse an image to mask out areas for the deformer to not function.Video Loader
