Block Glitch
Block Glitch
Add an animated block glitch.
This node generated an effect of digital blocks periodically displacing the image and altering their colours.
Block Size Pixel size of the blocks the image will be broken into.
Breakup Amount How much the blocks are broken up.
Breakup Frame Amount How far apart the blocks are moved when breaking up.
Breakup Size How large each block is.
Displace Amount How much to displace the image when broken up.
Glitch Rate How often the glitch frames appear.
Glitch Duration How long the glitch frames last.
Use Num Blocks Use the ‘Num Blocks X & Y’ attributes to define the number of blocks across the X and Y axis instead of using the ‘Block Size’ attribute.
Num Blocks X Define the number of blocks across the X axis of the image. Only used if ‘Use Num Blocks’ is enabled.
Num Blocks Y Define the number of blocks across the Y axis of the image. Only used if ‘Use Num Blocks’ is enabled.
Block Colour Mode How to colour the generated blocks.
  • Colour : Colours the generated blocks.
  • Greyscale : De-saturates the blocks.
  • None : Does not colour the blocks, just uses original image colours.
