Render Particles To Surfaces
Renders particles onto nearby Meshes.Updated: 15 Sep 2026
Renders particles onto nearby Meshes.This node renders particles onto nearby 3D surfaces. This means that instead of rendering particles directly into space, they instead appear as dots on 3D geometry, only being visible when they are within a certain proximity to 3D geometry. This is particularly useful when attempting to render particles in a scene rendered by a UV Camera. A spatial grid is used to evaluate the particles, so you may need to add a bounding box and adjust its scale to make sure the particles are evaluated correctly. Reducing the particle size is also a useful step for getting a reasonable quality result.
An image may also be used on the particles, by adding one to the Texture parameter. If an image is not used the sprites will render as a circle with falloff based on particle proximity. The alpha channel of a supplied image is also used to affect particle transparency.
| Texture | Select a texture to be rendered at each particles position. |
| Output Target |
Determines which channel the effect is rendered to.
| Particle Blend Mode |
Choose how the particle colours blend to the source colours.
| Particle Alpha | Change the alpha value for the particles. |
| Particle Size | Edit the size of the particles once they are rendered. |
| Size Randomness | Control the randomness in size of the particles. |
| Particle X Scale | Control the x-scale of the sprites emitted. |
| Particle Y Scale | Control the x-scale of the sprites emitted. |
| Pixel-Align Output | Align the rendered points exactly to screen pixels, with no sub-pixel interpolation. |
| Particle Scale Coeffs | How much the particle scales are affected by the node at different stages of the particle life. Values 1 and 2 are control points, and are used to control the curve between values 0 and 3. |
| Screen Size Limits | The minimum and maximum size of the rendered particle in normalised screen coordiates. |
| Specify Size Limits In Pixels | Indicates whether particle size limits are specified in normalised viewport coordinates which are consistent across different render resolutions, or in pixels. |
| Luminance Randomness | Control how much randomness is in the luminance of the rendered particles. |
| Rotation Randomness | Control how much randomness is in the rotation of the particles. |
| Rotation Follows Direction | Toggle whether the rotation of the particles follows the direction the particle is moving in. |
| Sort Key Value | Biases the depth-based render order, to force the particle system to be drawn before or after other objects in the scene. |
| Depth Bias | Offsets particles in depth so they are closer or further away from the camera, changing the point at which they intersect with the rest of the scene. |
| Motion Blur Amount | Control the amount of motion blur. |
| Use Texture Animation | Edit whether the texture animation is shown with the rendering. |
| Texture Animation Rate | Edit whether the texture animation is shown with the rendering. |
| Num Frames X | Change how many tiles the sprite image will be spread across the x axis. |
| Num Frames Y | Change how many tiles the sprite image will be spread across the y axis. |
| Randomise Start Frame | Randomises the beginning frame the texture animation is played from. |
| Bounds Node | The bounding box within which particles are rendered. | Bounding Box |
| Affected Object Nodes | Objects to render to particle to. | 3D Object |
| Rendered Emitters | Specify which emitters are rendered using this renderer. By default, all emitters connected to the same particle root as the renderer are rendered. | Primitive Emitter |
