Gradient Remap
Remap modifier values based on a custom gradient.Updated: 15 Sep 2026
Remap modifier values based on a custom gradient.This node remaps incoming modifier values based on a user created gradient. Values outside of 0 and 1 are clamped.
| Value | Base value to modify the output value with. |
| Gradient | Gradient used to remap values. Double click on the visual gradient to create a new node at that position. Click and drag on a node vertically to change the value at that position. Click and drag on a node horizontally to change the position at that value. |
| Modifier Operation |
What operation is done to the modified attribute.
