Kinect Surface Mask
Kinect Surface Mask
Updated: 7 Oct 2025
Creates a image representing surface of the kinect data.
This node creates an image representing the surface of the kinect data and colours it by the normal direction of surface.
Legacy Effect Mask Blend Blend input masks using the legacy behaviour kept for pre-2022 scenes. Leave disabled for new compositions.
Surface Heading Offset the surfaces Y direction value from its current direction.
Surface Pitch Offset the surfaces Z direction value from its current direction.
Falloff The strength of the effect.
Bounding BoxLimits the area that the effect will use.Bounding Box
