Displacement Map
Displacement Map
Displaces geometry based on an input image
This node displaces the vertices of a mesh based on an image or video. Useful with height or displacement textures, to add extra depth and definition to the surfaces.
  • Local :
  • World :
  • Normal :
  • Spherical :
  • Planar :
Image Override the input image with an image selected from the drop down menu.
ImageImage used to displace the mesh.Video Loader
Shading NodeUse a shading node to control displacement.Fractal Noise
