Frame Buffer
Hold a frame of video for a period of time.
This node periodically holds a frame to a frame buffer for a short period of time, before updating based on the “Frame Grab Rate”. Useful for quickly grabbing a frame to hold onto in the scene, or for giving the appearance of lowering the frame rate of a video while allowing other effects to continue to update at the correct rate.
| Frame Grab Active | Controls whether the frame buffer is actively collecting frames to store in its buffer. |
| Frame Grab Rate | The amount of time in seconds between each frame being grabbed. |
