Level Set (Field)
Level Set (Field)
This node allows a Field to be used as a procedural generator source.
This node allows a Field System to be used as a procedural generator source. This path is useful for generating fluid like meshes via the Procedural Meshing Node.
Affect Colour Toggles whether colour is used or not.
Field SourceConnect a Field Level Set root to generate the procedural shape.Field Level Set Root
