OSC Output
OSC Output
Send an OSC message every frame.
Sends an OSC message with a single numeric/float value every frame, to the target IP and Port number set in Project Settings.
OSC messages will only be sent when the play head is playing.
See OSC Topic for more details.
Value The numeric value to be sent. Often a linked value.
Send Active Control whether OSC messages are being sent.
Send On Change Only sends an OSC update when the incoming value changes.
OSC Address The OSC address for the message. Must start with a /. e.g. /myoutput/x
OSC AddressThe OSC address to transmit this node’s output to.[Any]
