MIDI To Texture
Generates a texture based on a connected MIDI Keyboard.
This node generates a texture based on the output from a connected MIDI Device. Useful for visualising the inputs of a MIDI Keyboard, with standard attack/decay controls.
| Preview In Viewport |
| Format | Change the format of the generated image. |
| Update Time Mode |
| Device | Select an input device to use. |
| Channel | Select a channel from the device to listen to. |
| Attack | Controls the initial time between the current values to the peak. |
| Decay | Controls the time between the peak to the sustain level. |
| Min Value | Acts as a minimum threshold for extracting a range of values from the waveform. |
| Max Value | Acts as a maximum threshold for extracting a range of values from the waveform. |
| Max Clamp | A maximum value which values will be clamped if they go above. |
| Spikiness | Accentuates peaks in the waveform so they are sharper. |
| Scale | How much the output values are scaled. |
| Offset | Offset all values output by the texture. |
| Smoothness | How much smoothing is applied between differing values. |
| Falloff Range | Range in which the sounds data will be tracked. |
| Blend Mode |
