XSens Mocap Skeleton
Control skeletal rigs from an Xsens mocap system.Updated: 15 Sep 2026
Control skeletal rigs from an Xsens mocap system.This node reads bone data from a XSens motion capture suit and applies it to Bone nodes, either via direct input links or by a connection to the root of the target hierarchy.
A network connection must be made to the XSens software which provides a stream of bone data from the suit. The server address and port must be entered to match the output address and port in XSens. If there is no connection the node will be hatched out in red.
Please be advised you can only import one live stream into a notch project at a time.
Imported characters tend work best with Convert FBX disabled on import, and Rotate Bind Joints enabled. Although, because rigged characters can come from various sources with different standards, you may need to try a few different combinations to see which works right for your character.
| Server Address | The address / IP of the XSens server providing the skeleton stream. |
| Server Port | The port of the XSens server providing the skeleton stream. |
| Avatar Index | Select the mocap actor to drive the skeleton. |
| Input Skeleton Scale | Uniformly scale the size of the input mocap skeleton. |
| Xsens Stream | The Stream to read the MoCap Data from. |
| Hierarchy Root | The root of the input skeleton to be driven by motion capture. | You’ll need to connect the skeleton root within an 3D Scene. |
