Pixel Sort
Add a simple pixels sorting algorithm to the image.
This node analyses the image for its brightest areas, and sorts the pixels darker than this bright spot by luminance along a chosen axis.
| Brightness Threshold | Threshold below which values will be blended into the data mosh. |
| Mask Threshold | TBC. |
| Direction | Select which direction the pixels are sorted in. |
| Mask Image | Use a mask image to control where the output is most or least affected by the effect, based on the mask images luminance. | Video Loader |
| Blend Image | A greyscale map controlling where the pixel sorting takes place. | [Image] |
