Ocean Wave Deformer
Ocean Wave Deformer
Deforms geometry based on a simple ocean wave simulation
This node displaces the vertices of a mesh based on an ocean wave function, with layered noises on top of a sine functions.
  • Local :
  • World :
Choppy Displacement Controls the lateral displacement of the deformer.
Animation Speed Speed the deformer is animated at.
