Float Array To Points
Updated: 19 Jun 2026
Creates a set of points from a float array.
This node takes a Float Array as an input, and uses it to create a set of 3d points. Each point is visualised directly by the node, with basic spheres of any radius and a material input.
This can then be used like any other 3D node within your project, and can be connected to a Mesh Cloner or a Transform Array to instantiate clones or distinct copies of other nodes based on the points of the array.
The float array can be created from a Float Array node, a CSV Float Array node or an OSC Float Array node. This can be a useful way of getting multiple sets of position data from external sources into Notch to be able to use them.
The float array provided to the node will be interpreted in either 1D, 2D or 3D. The padding property can be used to determine how extra bits of data sit between the values you want to use to create your points.
Dimension Determines how many axis of data you are creating points from.
  • 1D : 1 dimensional, points will be created along the x-axis.
  • 2D : 2 dimensional, points will be created in the x-y plane.
  • 3D : 3 dimensional, points will be created in x,y,z space.
Padding The amount of float values from the array that separate what you want to create points from.
Offset Determines what index of the float array will be read as the first value.
Radius Determines the radius of the spheres that are created at each point.
BSDF
  • Off :
  • Tangent Space :
  • Object Space :
Normal Map Intensity TODO
  • Off :
  • On :
  • Solid :
  • Blend :
  • Clip :
  • Solid :
  • Linear :
  • Additive :
  • Subtractive :
  • Multiply :
  • Max :
  • Min :
  • Screen :
  • Light :
  • Pre-Mul Blend :
  • Off :
  • Refraction :
  • Subsurface Scattering :
  • Single Sided SSS :
Refraction IOR TODO
Aberration TODO
Diffuse Coat TODO
  • Off :
  • On :
Baked Diffuse Intensity TODO
  • Off :
  • On :
Textures
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
UVs
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • Repeat :
  • Clamp :
  • Border With Black :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
  • Repeat :
  • Clamp :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
Lighting
  • Full Reflections :
  • Env Map :
  • Off :
  • Cast + Receive :
  • Cast :
  • Receive :
  • Off :
  • Full :
  • Unseen by Rays :
  • Unseen by Camera :
  • Use Global Settings :
  • Override :
Geometry
  • Front :
  • Back :
  • Double Sided :
FX
  • Off :
  • Rim Lighting :
Rim Lighting Colour TODO
Rim Lighting Intensity TODO
Rim Lighting Falloff TODO
Vertex Colours
  • No :
  • Multiply by RGB :
  • Multiply by Red :
  • Multiply by Green :
  • Multiply by Blue :
  • Multiply by Alpha :
  • Multiply by Inv Red :
  • Multiply by Inv Green :
  • Multiply by Inv Blue :
  • Multiply by Inv Alpha :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
Float ArrayThe float array that will be used to create the points.Float Array
