MDD Deformer
MDD Deformer
Deform a mesh based on an MDD file
This node deforms a mesh based on an MDD file. MDD files are linked to the mesh they are exported with, and not all tools can export them.
MDD File Source file for the MDD Deformation.
Playback Time Absolute time the animation is played at.
Loop Start If the MDD Deformer loops, choose where it loops back to.
Playback Offset Offset the time the MDD deformer starts at.
Playback Speed The speed at which the MDD deformer animates.
Loop Mode Control how the animation is after finishing
  • Play Once : The animation plays once and no longer effects the mesh.
  • Looping : The animation loops infinitely.
Blend Mode Choose how the falloff blends with the model.
  • None : No falloff is applied.
  • Blend : Finds a middle value between its deformation and the model’s current positions.
  • Additive : Always adds the new deformation on top of the model’s current positions.
Falloff Controls the falloff of the MDD deformation.
