3D Plasma Deformer
Deforms geometry based on overlapping sine wavesUpdated: 15 Sep 2026
Deforms geometry based on overlapping sine wavesThis node deforms vertices based on a number of sine waves which form a plasma-like effect. This can be used to create soft spikes on the surface of an object.
| Weightmap | Add a weight map to determine where the deformer is more or less effective. |
| Apply Mode |
Choose whether the deformer applies to the individual vertices or the mesh chunks.
| Transform Space |
Choose which transform space the deformer uses for deformation. Does not affect falloffs.
| Displacement Direction |
Change the direction the deformer displaces the mesh.
| Blend Amount | Global override for how much the deformer affects the mesh. |
| Num Spikes X | Number of spikes along the x axis. |
| Num Spikes Y | Number of spikes along the y axis. |
| Num Spikes Z | Number of spikes along the z axis. |
| Spikiness | How sharp the spikes are in the deformer. |
| Max Displacement | Maximum distance the deformer can displace the mesh. |
| Animation Speed | Speed the deformer is animated at. |
| Time Mode |
How the deformer updates with relation to the timecode.
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Mask Image | Use an image to mask out areas for the deformer to not function. | Video Loader |
| Generated Weightmap | Add a weightmap to vary the strength of the deformer across the surface. | Generate Weightmap |
