Array Copy
Creates a copy of the points from an Array.
This node copies the data from an Array Source so that you can use the same Array in multiple places across a nodegraph. This is useful when doing interactive setups and you want a ’touch point’ to do multiple different things, such as render an object and emit particles.
The output is a transform array like any other – which may be used directly with a Array Cloner, or to clone other nodes within a Field System or Particle System.
| Apply Node Transform To Array Elements Only | When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used. |
| Ease Points On | Enable Point Easing in, so new points don’t immediately appear. |
| Ease Points On Mode |
| Ease Points On Duration | How long the points should take to fully appear. |
| Ease Points Off | Enable Point Easing out, so removed points don’t immediately disappear. |
| Ease Points Off Mode |
| Ease Points Off Duration | How long the points should take to fully disappear. |
| Easing Affects Point Scales | Apply the easing to the scale of each point in the array, not just their positions. |
| Easing Affects Point Opacities | Apply the easing to the opacity of each point in the array, not just their positions. |
| Point Array Source | The point array to copy, with the easing and effects applied per element. | [Point Array] |
| Bounding Box | Overwrite the bounds of the input Array | Region Camera |
