OSC Modifier
OSC Modifier
Receive a modifier value over OSC.
This nodes receives a numeric float or integer value via the OSC protocol over a network, and outputs it as a modifier value. See OSC Topic for more details.
If the node is red hashed out, this means the node isn’t receiving data. This is either because an OSC address/port needs to be set, or because OSC needs to be enabled in the Project>Settings>Protocols window.
The incoming OSC values will only be processed when the play head is playing.
This node can be used to receive multiple values from one message by using the OSC Channel Value Index parameter. This lets you control the index of the value you want to receive from the message’s arguments.
OSC Address The address (which must start with a /)of the OSC value being received e.g. /myvalue/x
OSC Channel Value Index Select a specific value from an array of input OSC Values.
Offset Applies an offset (post scale) to the calculated value.
