Plain Deformer
Plain Deformer
Deforms geometry based on its position and a set transform direction
This node deforms using a simple displacement using proximity to a point, and a direction to displace.
  • Local :
  • World :
Transform Mode How the transform data is interpreted by Notch.
  • Transform :
  • Centre :
  • Normalise :
  • Fit To Bounds :
  • Locked To Timecode :
  • Running / Loopable :
These properties control how the deformer transforms the mesh.
Transform NodeUse an input node to drive the transformation values of the deformer.Null
