Apply Colour LUT
Apply Colour LUT
Apply a Colour Look Up Table (LUT) to an image.
This node applies a Colour Look Up Table to the Image. Colour Look Up Tables (LUTs) are a method of transforming the colours of an image. They are used extensively in colour grading in post production. Notch supports the standard 3D LUT format of .cube, exported by the vast majority of colour grading packages.
Cube LUT The imported .cube resource.
LUT Working Colour Space The colour space in which to apply the lut. this should be matched to the space in which the lut was authored.
  • Gamma 2.2 : Convert the input colours to gamma 2.2 space before applying the LUT.
  • Linear : Convert the input colours to linear space before applying the LUT.
Apply To Filled Pixel Only Only apply to pixels with some content on them. useful for virtual production contexts, where post-fx applied to the front plate shouldn’t apply over the backplate.
