CSV/Table Read Modifier
Reads a value from a table cell for modifiers.
This node reads in values from an imported table cell, and outputs it ready for use in a modifier system.
You can add tables in the Resource Panel via Interactive-> CSV/Text File
CSV File The table resource.
Read Index In a 2D table, this is the column to be picked from. In a 1D list this is the index to pick.
Row Index In a 2D table, this is the row to be picked from.
Selection Mode Which method to use to select the value form the CSV table.
  • Index : A row of separated values.
  • 2D - Column + Row : The more traditional table layout.
