Directional Light
Directional Light
Emit light from an infinite distance.
Add a directional light node to a scene to produce ambient directional lighting throughout. Light is emitted in a parallel direction at the normal to an infinite plane.
Directional lights only cast shadows with raytracing enabled.
Apply Specular Control whether this light applies specular light onto objects.
Apply Diffuse Control whether this light applies diffuse light onto objects.
Show Light Cone Show a cone in the scene to represent the lights current position and rotation.
These properties control shadow properties from the light.
Casts Shadows Determines whether this light will cast shadows.
Shadow Softness Change how much softness is applied to the shadow edges.
Z Bias Increasing Z bias will improve the accuracy of grounding objects to their shadows.
Projection ImageControls the direction the image is projected from, independant of the light. Only functions if an image is being projected from the light.Video Loader
