Bump Map Warp
Bump Map Warp
Warps an image based off of a bump map.
This node warps an image based off of a bump map. The warp is generated by creating a copy of the image with a slight offset and multiplied. If there is no input connected to the Image Node input then the scene render is used as a source bump map.
Displacement X Amount How strongly the bump map displaces the image along X.
Displacement Y Amount How strongly the bump map displaces the image along Y.
Texture Wrap Mode U Controls the wrapping mode for the texture in the U direction.
Texture Wrap Mode V Controls the wrapping mode for the texture in the V direction.
Falloff Range How far the falloff for the warp reaches.
Bias Displacement Direction (Grey = 0) Change the displacement direction so that a middle grey value has no displacement, and values darker or brighter will push the displacement in opposite directions.
Normalise Displacement Direction Force the displacement direction to apply evenly in each direction. this does not include alpha modulation.
Modulate Displacement Amount By Alpha Control the strength of the displacement based on the input images alpha channel
Control how much the RGBA channels displace the X and Y axes individually.
Displacement X - Red How much the red channel of the bump map contributes to the X displacement.
Displacement X - Green How much the green channel of the bump map contributes to the X displacement.
Displacement X - Blue How much the blue channel of the bump map contributes to the X displacement.
Displacement X - Alpha How much the alpha channel of the bump map contributes to the X displacement.
Displacement Y - Red How much the red channel of the bump map contributes to the Y displacement.
Displacement Y - Green How much the green channel of the bump map contributes to the Y displacement.
Displacement Y - Blue How much the blue channel of the bump map contributes to the Y displacement.
Displacement Y - Alpha How much the alpha channel of the bump map contributes to the Y displacement.
Image NodeThe source bump map for the warp.Video Loader
