Sound Texture
Generates an image based on the sound an audio source.
This node generates a texture based on the sound from either a selected or input audio source. The generated texture can then be modified using the same Attack/Decay tools as a sound modifier.
| Preview In Viewport |
| Format | Change the format of the generated image. |
| Update Time Mode |
| Sound | Sound file used to drive the effect. |
| Looping | Control whether the sound loops once it ends |
| Channel | Which audio channel is used. |
| Band EQ | Selects and weights the frequency bands to be used from the sound file. |
| Time Offset | Offset the time the clones are modified from the time the waveform is at. |
| Change Threshold | Changes the threshold for what counts toward the effect. |
| Attack | Controls the initial time between the current values to the peak. |
| Decay | Controls the time between the peak to the sustain level. |
| Min Value | Acts as a minimum threshold for extracting a range of values from the waveform. |
| Max Value | Acts as a maximum threshold for extracting a range of values from the waveform. |
| Max Clamp | A maximum value which values will be clamped if they go above. |
| Spikiness | Accentuates peaks in the waveform so they are sharper. |
| Scale | How much the output values are scaled. |
| Offset | Offset all values output by the texture. |
| Smoothness | How much smoothing is applied between differing values. |
| Decay Buffer Size | Size of the buffer used for sourcing the decay |
| Falloff Range | Range in which the sounds data will be tracked. |
| Waveform | Visualises the waveform of of the sound. |
| Blend Mode |
| Sound | Use an input sound to override the sound attribute. | Sound Loader |
