Bezier Warp
Bezier Warp
Warps using a bezier control grid and 8 control points.
This node warps an image using a bezier control grid and 8 control points.
Show Control Points Visualise the control points being used to warp the image.
Central points used to warp the image.
Centre Point 0 X The X position (0-1) of the Bezier curve centre control point 1 of the warp.
Centre Point 0 Y The Y position (0-1) of the Bezier curve centre control point 1 of the warp.
Centre Point 1 X The X position (0-1) of the Bezier curve centre control point 2 of the warp.
Centre Point 1 Y The Y position (0-1) of the Bezier curve centre control point 2 of the warp.
Centre Point 2 X The X position (0-1) of the Bezier curve centre control point 3 of the warp.
Centre Point 2 Y The Y position (0-1) of the Bezier curve centre control point 3 of the warp.
Centre Point 3 X The X position (0-1) of the Bezier curve centre control point 4 of the warp.
Centre Point 3 Y The Y position (0-1) of the Bezier curve centre control point 4 of the warp.
Outer points used to warp the image.
Corner Point 0 X The X position (0-1) of the Bezier curve corner 1 of the warp.
Corner Point 0 Y The Y position (0-1) of the Bezier curve corner 1 of the warp.
Corner Point 1 X The X position (0-1) of the Bezier curve corner 2 of the warp.
Corner Point 1 Y The Y position (0-1) of the Bezier curve corner 2 of the warp.
Corner Point 2 X The X position (0-1) of the Bezier curve corner 3 of the warp.
Corner Point 2 Y The Y position (0-1) of the Bezier curve corner 3 of the warp.
Corner Point 3 X The X position (0-1) of the Bezier curve corner 4 of the warp.
Corner Point 3 Y The Y position (0-1) of the Bezier curve corner 4 of the warp.
