2D Primitive
2D Primitive
Updated: 28 Jan 2025
Generates a 2D Primitive Mesh
This node generates a 2D primitive mesh, chosen from the nodes Shape Type property. Typically used in a 2D system under a 2D Root to generate simple 2D shapes, but is equally applicable to 3D scenes.
This node outputs the normal transformation and translation values, but it also outputs geometry which can be modified with Deformer nodes, or used as a mesh sources for nodes which accept mesh connections, such as the Field Mesh Emitter or the Procedural Mesh. A Material Node can also be input to control the meshes material properties.
Edit Pivot TODO
Shape Type Choose which 2D shape is rendered.
  • Box : Simple box with capability for additional subdivisions and bevel.
  • Circle : Simple sphere with capability for additional subdivisions and an inner hole.
  • Capsule : Simple pill shape which generates dynamically based on the subdivisions and defined size.
  • Arrow : Simple Arrow shape with various controls over arrow shape, width, length, subdivisions, and many more.
Size Mode Choose if the properties define the radius or diameter of the shape.
  • Radius : 1 unit measures the distance between center to the bounds.
  • Diameter : 1 unit measures the distance between the object bounds.
  • Corners : 1 unit measures from one corner to the opposite corner.
X0 The X position of the rectangle’s first corner, in texture space (0-1).
Y0 The Y position of the rectangle’s first corner, in texture space (0-1).
X1 The X position of the rectangle’s second corner, in texture space (0-1).
Y1 The Y position of the rectangle’s second corner, in texture space (0-1).
Inner Radius Alter the inner radius up to which the affector is fully effective.
Start Angle TODO
End Angle TODO
Lock Subdivisions To Angles TODO
Size X Size of the object along the X axis
Size Y Size of the object along the Y axis
Bevel Radius The radius of the rounded corners of the object.
Subdivisions The number of subdivisions of each connection line.
Bevel Subdivisions Number of subdivisions used to form the bevel.
Box Subdivisions X Number of subdivisions used for the Box shape on the X axis.
Box Subdivisions Y Number of subdivisions used for the Box shape on the Y axis.
Origin X Set the objects origin point for the X axis.
  • -Size : Sets the objects origin to the objects bound in the negative X direction.
  • Centre (Zero) : Sets the objects origin to the objects center.
  • +Size : Sets the objects origin to the objects bound in the positive X direction.
Origin Y Set the objects origin point for the Y axis.
  • -Size : Sets the objects origin to the objects bound in the negative Y direction.
  • +Size : Sets the objects origin to the objects bound in the positive Y direction.
Arrow Shape TODO
  • Arrowhead :
  • 45 Degrees :
  • Straight :
Tip Length TODO
Tip Width TODO
Shaft Width TODO
Shaft Length TODO
Primitive Vertex Count Shows the original vertex count of the primitive at generation.
Primitive Polygon Count Shows the original polygon count of the primitive at generation.
Post-Deformer Vertex Count Shows the current vertex count of the primitive after all the deformers have been applied.
Post-Deformer Polygon Count Shows the current polygon count of the primitive after all the deformers have been applied.
Render Z Only When enabled, the 3D object is only rendered to the depth buffer in the main camera render. No colour data is rendered.
Render To Shadows Only When enabled, this object isn’t rendered to the camera but will render shadows still.
These properties control how the UVs of the mesh are transformed when output for the UV camera. Useful for arranging multiple objects to be output for the same UV Camera.
Show Metrics Displays information about the mesh geometry.
These properties control the behavious of the object in a Physics System.
  • Linear : The line rendering is blended with the rest of the content in the scene.
BSDF
  • Off :
  • Tangent Space :
  • Object Space :
Normal Map Intensity TODO
  • Off :
  • On :
  • Solid :
  • Blend :
  • Clip :
  • Solid :
  • Linear :
  • Additive :
  • Subtractive :
  • Multiply :
  • Max :
  • Min :
  • Screen :
  • Light :
  • Pre-Mul Blend :
  • Off :
  • Refraction :
  • Subsurface Scattering :
  • Single Sided SSS :
Refraction IOR TODO
Aberration TODO
Diffuse Coat TODO
  • Off :
  • On :
Baked Diffuse Intensity TODO
  • Off :
  • On :
Textures
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
UVs
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • UV 1 :
  • UV 2 :
  • UV 3 :
  • UV 4 :
  • Repeat :
  • Clamp :
  • Border With Black :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
  • Point :
  • Bilinear :
  • Anisotropic :
  • Bicubic :
  • Oversampling :
  • Repeat :
  • Clamp :
  • Mirror :
  • Repeat :
  • Clamp :
  • Mirror :
Lighting
  • Full Reflections :
  • Env Map :
  • Off :
  • Cast + Receive :
  • Cast :
  • Receive :
  • Off :
  • Full :
  • Unseen by Rays :
  • Unseen by Camera :
  • Use Global Settings :
  • Override :
Geometry
  • Front :
  • Back :
  • Double Sided :
FX
  • Off :
  • Rim Lighting :
Rim Lighting Colour TODO
Rim Lighting Intensity TODO
Rim Lighting Falloff TODO
Vertex Colours
  • No :
  • Multiply by RGB :
  • Multiply by Red :
  • Multiply by Green :
  • Multiply by Blue :
  • Multiply by Alpha :
  • Multiply by Inv Red :
  • Multiply by Inv Green :
  • Multiply by Inv Blue :
  • Multiply by Inv Alpha :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • No :
  • Multiply by Red :
  • Static :
  • Kinematic :
  • Dynamic :
  • Dynamic After Collision :
  • Disabled :
  • Baked :
GPU Transform Only If selected, the transform of the body is maintained on GPU only. This reduces latency and increases performance but means that parenting to the object, e.g. using it to transform lights or emitters, will not work.
  • Sphere :
  • Box :
  • Plane :
  • 3D Object (Convex Hull) :
  • 3D Object (Use Original Geometry) :
  • 10 Faces (Cylinder) X-Axis :
  • 10 Faces (Cylinder) Y-Axis :
  • 10 Faces (Cylinder) Z-Axis :
  • 14 Faces (Capsule) X-Axis :
  • 14 Faces (Capsule) Y-Axis :
  • 14 Faces (Capsule) Z-Axis :
  • 18 Faces (Rounded Box) :
Rigid Body Chunks Mode Set whether to treat the object as one single rigid body, or whether to calculate physics for each chunk.
  • One Rigid Body :
  • Multi Body :
Max Chunks When using ‘Multi Body’ chunk mode, set the maximum amount of chunks that can be calculated. Useful for performance optimisation.
Mass Center X Adjust the object’s center of mass along the X axis
Mass Center Y Adjust the object’s center of mass along the Y axis
Mass Center Z Adjust the object’s center of mass along the Z axis
Advanced TODO
  • Volumetric :
  • Surface :
Rigid Body Sphere Radius TODO
Rigid Body Box Size X TODO
Rigid Body Box Size Y TODO
Rigid Body Box Size Z TODO
Bake Physics Transforms Bake physics transforms so they are no longer dynamic, but reliably playback and are more performant.
Baked Transform Select the baked physics transform.
Colour TextureA texture to apply to the object that defines its colour.Video Loader
