Optitrack Mocap Skeleton
Control skeletal rigs from an OptiTrack system.Updated: 15 Sep 2026
Control skeletal rigs from an OptiTrack system.This node reads bone data from a OptiTrack motion capture suit and applies it to Bone nodes, either via direct input links or by a connection to the root of the target hierarchy. A network connection must be made to the OptiTrack software which provides a stream of bone data from the suit. This is done via the Project Settings menu under the Tracking Protocols -> Motive section - use the “Motive” connection options.
Entering the IP of the target system can be unreliable in some cases, so we generally advise you leave the IP address blank. This will use the OptiTrack SDK to search for the OptiTrack system automatically, and is much more reliable at getting a connection. If that doesn’t work, it’s likely there is an issue with your network setup, as in that case the SDK itself can’t find it on the network at all.
OptiTrack is only available to RFX users, so Indie and VFX licenses won’t be able to use this feature.
| Avatar Index | Select the mocap actor to drive the skeleton. |
| Rotate Bind Pose Joints By Facing Direction | Determines whether the input skeleton has been rigged so that the bones in their bind pose are rotated to point in the direction of the next bone, or whether they are unrotated in their bind pose. |
| Input Skeleton Scale | Uniformly scale the size of the input mocap skeleton. |
| Optitrack Stream | Select an Optitrack Stream file. |
| Hierarchy Root | The root of the input skeleton to be driven by motion capture. | You’ll need to connect the skeleton root within an 3D Scene. |
