Motion Datamosh
Add a datamosh effect to the image.
This node generates datamoshing using the movement vectors of the image, or an input velocity image.
This node is frame rate dependent, so changes in frame rate can heavily impact the results.
| Velocity Scale | How much the velocity data affects the image. |
| Hold Time | How long the image will be held before getting a new frame. |
| Velocity Update Rate | How many times per second the motion data will update with the image. |
| Use Scene Motion Vectors | Use the motion vectors from within the scene. |
| Velocity Image | Use an input image to decide how the datamoshing should be applied. | Optical Flow |
| Hold Time Image | Use an image to decided how different parts of the image hold their datamosh-ed state. | Video Loader |
| Velocity Mask Image | Use an image to mask out areas where the datatmoshing wont be applied. | Video Loader |
