Voronoi Node
Generates a 3D Voronoi pattern for procedurals.
Generates a 3D Voronoi pattern based on an input particle system. If no particle root is plugged in, then a default infinite pattern will be used.
| Num Particles | Number of particles to be used to generate the voronoi shape. |
| Mode |
Select how the voronoi points are sourced.
| CSG Mode |
These options change how a this procedural node combines with the existing of the procedural system.
| CSG Blend Weight | How much the new procedural blends with the old procedurals, depending on the CSG Blend Weight. |
| Particle Node | Connect a particle system to generate the procedural shape. | Particle Root |
