Distance Shading
Distance Shading
Shades particles based on their distance from a point.
This node shades particles based on their distance from a shape. The shape type is chosen using the Distance Mode parameter. Distance from the chosen shape is then calculated and a falloff function is used to produce a value that is used for shading. The distance calculation may be inverted so that the shading result is greater when further away from the shape.
Position X Position x in local space
Position Y Position y in local space
Position Z Position z in local space
Rotation Heading Rotation around y axis in local space
Rotation Pitch Rotation around x axis in local space
Rotation Bank Rotation around z axis in local space
Scale X Scale along the x axis in local space
Scale Y Scale along the y axis in local space
Scale Z Scale along the z axis in local space
Distance Mode Choose what shape the particles are calculated to be a distance from.
  • Point : A point is used.
  • Line : A line is used.
  • Plane : A plane is used.
Radius Outer radius for which the particles will no longer be coloured.
Inner Radius Inner radius for which the particles will be coloured at their max.
Falloff Power How quickly the gradient changes from the inner radius to the outer radius.
Colour Change the colour of the particles as they spawn.
Invert Distance toggle whether the calculation is done for inside or outside the inner radius.
Blend Mode Choose how the particle colours blend to the source colours.
Blend Amount Control how much the new shading affects the particles.
Position NodeOverrides the transform of the shape used to calculate the distance.Null
