Array Average
Combines the points from an array to a single transform.
This node takes the points from an array and combines them based on the mode selected, to form a single output transform. Useful for extracting a particular transform in an array and using to control other elements in the scene.
| Mode |
Change what the array node does with the list of array nodes.
| Point Array | Array of points used to perform operations based on. | Transform Array |
| Reference Point | Used with Closest To Point mode, the point which is checked against. | Null |
