Perception Neuron Mocap Skeleton
Control skeletal rigs from a Perception Nueron system.Updated: 15 Sep 2026
Control skeletal rigs from a Perception Nueron system.This node reads bone data from a Perception Neuron motion capture suit and applies it to Bone nodes, either via direct input links or by a connection to the root of the target hierarchy. A network connection must be made to the Axis Neuron software which provides a stream of bone data from the suit. The server address and port must be entered to match the output address and port in Axis Neuron. If there is no connection the node will be hatched out in red.
| Axis Neuron Server Address | The address / IP of the Axis Neuron server providing the skeleton stream. |
| Axis Neuron Server Port | The port of the Axis Neuron server providing the skeleton stream. |
| Avatar Index | Select the mocap actor to drive the skeleton. |
| Input Skeleton Scale | Uniformly scale the size of the input mocap skeleton. |
| Hierarchy Root | The root of the input skeleton to be driven by motion capture. | You’ll need to connect the skeleton root within an 3D Scene. |
| Mocap Stream | Input a pre-recorded mocap stream to run instead of any live data. | Mocap Stream |
| Hips | The transform of the Hips joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightUpLeg | The transform of the right thigh joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightLeg | The transform of the right shin joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightToeBase | The transform of the right toe base joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftUpLeg | The transform of the left thigh joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftLeg | The transform of the left shin joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftToeBase | The transform of the left toe base joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightShoulder | The transform of the right shoulder joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightArm | The transform of the right upper arm joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightForeArm | The transform of the right forearm joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| RightHand | The transform of the right hand joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftShoulder | The transform of the left shoulder joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftArm | The transform of the left upper arm joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftForeArm | The transform of the left forearm joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| LeftHand | The transform of the left hand joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| Head | The transform of the Head joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| Neck | The transform of the Neck joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| Spine3 | The transform of the upper chest spine joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| Spine2 | The transform of the chest spine joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| Spine1 | The transform of the upper spine joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
| Spine | The transform of the Spine joint, driven by the connected mocap or body tracking system. Connect child nodes here to make them follow that bone. | Null |
