Float Array
Float Array
Updated: 19 Jun 2026
Contains an array of float values
This node contains an array of float values.
Float arrays let you make collections of several float values in an array. This can be useful for several use cases, e.g.:
  • Sending and receiving lots of numeric data from external sources/software. This can be useful for integrating new hardware or control systems.
  • Reducing nodegraph complexity and working more efficiently by creating your own custom properties.
  • Setting multiple parameters on one node one connection.
  • Creating a set of points from a series of x,y,z positions.
Float arrays can be created using OSC, or generated from a CSV File.
They can be converted to custom parameters using the Custom Parameters node.
They can be used to create points using the Float Array To Points node.
The float array node itself lets you input an existing float array, and make a selection of the data within it using the Index Offset and Max Array Size properties.
Max Array Size Sets the maximum size of the float array. Any floats stored after this index in the arrayw ill be removed/cut off.
Index Offset Sets the starting point of the float array. Any floats stored before this index in the arrayw ill be removed/cut off.
Array Used for setting parameters
Float ArrayTakes a float array as an inputFloat Array
Parameter Value ArrayUsed to set the parameters fo the float arrayParameter Array
