Four Point Warp
Four Point Warp
Warps from 4 cornered sections of the image.
This Node allows the image to be warped from 4 cornered sections of the image.
Show Control Points Show the control points used in generating the effect.
Modify the control points for each of the four corners of the image.
Point 0 X The X position (0-1) of warp corner 1.
Point 0 Y The Y position (0-1) of warp corner 1.
Point 1 X The X position (0-1) of warp corner 2.
Point 1 Y The Y position (0-1) of warp corner 2.
Point 2 X The X position (0-1) of warp corner 3.
Point 2 Y The Y position (0-1) of warp corner 3.
Point 3 X The X position (0-1) of warp corner 4.
Point 3 Y The Y position (0-1) of warp corner 4.
