Ambient Light
Ambient Light
Add a light that applies to all surfaces equally.
This node emits a uniform light onto every surface in the scene. Useful for adding a little bit global illumination by raising the lowest levels of brightness in a scene.
This is a great tool for adding light to dark and shadowed areas.
Projection ImageAdd in an image to be projected by the light. Useful for adding gobos to lights, or making a simple projector light. Only works when the Light Type is set to Spot.Video Loader
