Cellular Noise
Generates a cellular noise pattern for a procedural.
This node generates an infinite cellular noise pattern. It works by dividing the space in to cells and placing a point in each cell, which is expanded to a sphere. the points are then randomly offset to form the cellular noise.
| Distance Offset | Offsets the distance field values, causing the generated distance field to expand of contract. |
| Cell Size | Size of the generated cells. |
| Jitter | How much the spheres are randomly moved from their original cell positions. |
| CSG Mode |
These options change how a this procedural node combines with the existing of the procedural system.
| CSG Blend Weight | How much the new procedural blends with the old procedurals, depending on the CSG Blend Weight. |
| CSG Stair Count | How many steps in the transition when using the “Stairs” CSG Mode. |
| Affect Colour | Affect the colour of the generated procedural system. only functions with ‘Generate Colours’ enabled in some Procedural Render nodes. |
| Always Enabled (No Time Bars) | When enabled, this node will run regardless of time bar enable/disable. Due to how Notch handles shader generation with procedurals, with this enabled the node runs more efficiently. |
| Material Colour | Modify the colour for the procedural material. |
| Custom CSG Code | Type your Custom code here, using the HLSL language. Read more on Editable Code. |
| Transform Controller | Set the origin/center point of the noise. | Null |
