Composition Precomp
Composition Precomp
Pre-composite a separate layer as a video source.
This node pre-composites a layer so it can be rendered inside another layer. Any exposed values from inside that layer will also be carried over into the new layer.
Multiple nodes in one scene will re-render that original layer, so make sure to use as few layer precomp nodes as possible and branch out with Video Nulls.
Outputs are an image or video that can be connected to any relevant video input, most commonly an Image 2D node, or a Post FX Node.
Source Composition Select a composition to precomposite.
Render Width Change the width of the rendered layer. When set to 0, the render width will match the current compositions resolution.
Render Height Change the height of the rendered layer. When set to 0, the render height will match the current compositions resolution.
Time Mode Change relative time in which the precomped layer is running.
  • Node Relative : Time will be relative to the start and end time of the node.
  • Layer Relative : Time will be relative to the start and end time of the layer.
  • Global : Time will be relative to the start and end time of the project.
  • Use Deltas (Looping) : Time will use its own time and run continuously.
Time Offset Offset the start time of the layer.
Playback Speed Speed at which the layer is played at.
Looping Enable or disable the layer from looping at the end.
Loop Start Time Offset the start time of the layer after each loop.
Update Active Enable or disable the layer from re-rendering to the current scene. When disabled, a static image will be output.
Optimise Memory Usage On Idle This will dynamically remove memory data if the node isn’t active. This can optimise memory usage, but can cause issues loading a precomp if it is sufficiently large.
Hide Handles, Bounding Boxes and Range Indicators Toggles the visibility of handles, bounding boxes and range indicators.
