Procedural Cloner
Procedural Cloner
Generates clones from a procedural system input.
This node generates clones based on a voxel representation of a procedural system. A voxel volume is defined by the bounding box, which then samples the procedural system to find whether the voxel is inside or outside the distance field. Voxels inside will then generate a clone, voxels outside will scale based on the distance threshold to 0, where they are de-spawned.
Position X Changes the x position of all clones from the previous clone.
Position Y Changes the y position of all clones from the previous clone.
Position Z Changes the z position of all clones from the previous clone.
Rotation Heading Changes the x rotation of all clones from the previous clone.
Rotation Pitch Changes the y rotation of all clones from the previous clone.
Rotation Bank Changes the rotation of all clones from the previous clone.
Scale X Changes the x scale of all clones from the previous clone.
Scale Y Changes the y scale of all clones from the previous clone.
Scale Z Changes the z scale of all clones from the previous clone.
Num Voxels X Number of voxels generated along the x axis.
Num Voxels Y Number of voxels generated along the y axis.
Num Voxels Z Number of voxels generated along the z axis.
Clone Distribution Mode Add variation to the size of clones and how they are distributed throughout the procedural.
  • Uniform : Scale and distribute all clones evenly throughout the procedural.
  • Variable : Vary the size and distribution of clones throughout the procedural.
Subdivide Levels How many variations of clone size and distribution should there be when using a variable distribution.
Rotate Clones By Normals Rotate clones to match the normals of the volume.
Scale Clones By Voxel Size Scales the cloned objects to match the voxel sizes.
Distance Threshold Outer threshold for the distance field.
Min Distance Threshold Inner threshold for the distance field.
Distance To Clone Size Scale Scale the clones based on distance from the center.
Rotation Stiffness How much clones resist rotating.
Scale Stiffness How much clones resist rotating.
Colour Clones Determines whether colour data from the transform array should be used to colour the clones.
Procedural RootSource Procedural System to generate clones from. A Procedural Root must be connected for the cloner to generate clones.Procedural Root
