Blacktrax Array
Generate an array using multiple Blacktrax Trackables as a source.Updated: 15 Sep 2026
Generate an array using multiple Blacktrax Trackables as a source.Takes multiple Blacktrax Trackables and instantiates the child nodes at the tracked points. You can track either the rigid body positions and rotation (Centroids) of given trackables or every LED of the trackable.
If you only wish to instantiate a subset of the trackables that Blacktrax is sending you can use the Trackable Filter attribute to set a prefix filter that all trackable ids must start with.
To enable listening to the Blacktrax data, you need to configure the Blacktrax options in menu: Devices->Mocap/Camera/Streaming Device Settings
A trackable is a Blacktrax name for a tracked object. It can either be a point, or rigid body.
| Trackable Type | Choose whether to take the centroid of all the LEDs or instantiate an array item for each LED |
| Use Blacktrax Rotations | Use the rotations passed through by Blacktrax. |
| Flip Z Axis | Flip positions in the Z axis |
| Trackable Filter | A prefix filter for the trackable names. |
| Apply Node Transform To Array Elements Only | When Enabled, transform changes applied to this nodes transform properties will also be applied to the array elements, and carried onto any nodes this data is used. |
