Linear Cloner
Updated: 8 Jan 2026
Generates clone in a linear pattern.
Updated: 8 Jan 2026
This node generates clones between two defined transform positions. The clones between these locations will linearly blend between both transforms.
| Node Spawn Mode |
Change the order in which the cloned objects are assigned to clone instances.
| Random Seed | The seed for the node’s random number generators. Change it to produce a different variation without altering the parameters. |
| Num Clones | Number of clones created. |
| First Clone | Chooses which clone is the first clone generated. |
| Clone Scale | Scale the size of all the clones uniformally. |
| Rotation Affects Clone Rotation | The rotation of the clones increases with each clone added. |
| Ease Clones In/Out | Enable easing so new clones don’t immediately appear. |
| Linear Size Mode |
| Position X Min | The minimum position the cloners will be generated from along the X axis. |
| Position X Max | The maximum position the cloners will be generated from along the X axis. |
| Position Y Min | The minimum position the cloners will be generated from along the Y axis. |
| Position Y Max | The maximum position the cloners will be generated from along the Y axis. |
| Position Z Min | The minimum position the cloners will be generated from along the Z axis. |
| Position Z Max | The maximum position the cloners will be generated from along the Z axis. |
| Rotation Heading Min | The minimum rotation the cloners will be generated from along their heading rotation. |
| Rotation Heading Max | The maximum rotation the cloners will be generated from along their heading rotation. |
| Rotation Pitch Min | The minimum rotation the cloners will be generated from along their pitch rotation. |
| Rotation Pitch Max | The maximum rotation the cloners will be generated from along their pitch rotation. |
| Rotation Bank Min | The minimum rotation the cloners will be generated from along their bank rotation. |
| Rotation Bank Max | The maximum rotation the cloners will be generated from along their bank rotation. |
| Scale X Min | The minimum scale the cloners will be generated from along the X axis. |
| Scale X Max | The maximum position the cloners will be generated from along the X axis. |
| Scale Y Min | The minimum scale the cloners will be generated from along the Y axis. |
| Scale Y Max | The maximum scale the cloners will be generated from along the Y axis. |
| Scale Z Min | The minimum scale the cloners will be generated from along the Z axis. |
| Scale Z Max | The maximum scale the cloners will be generated from along the Z axis. |
| UV Scale X Delta | Relative change to the uv scale along the x of the clone’s material, per clone. |
| UV Scale Y Delta | Relative change to the uv scale along the y of the clone’s material, per clone. |
| UV Offset X Delta | Relative change to the uv offset along the x axis of the clone’s material, per clone. |
| UV Offset Y Delta | Relative change to the uv offset along the y axis of the clone’s material, per clone. |
| Crop Left Delta | Relative change to the crop on the left of the clone’s uvs, per clone. |
| Crop Right Delta | Relative change to the crop on the right of the clone’s uvs, per clone. |
| Crop Top Delta | Relative change to the crop on the top of the clone’s uvs, per clone. |
| Crop Bottom Delta | Relative change to the crop on the bottom of the clone’s uvs, per clone. |
| Per Clone Position X | Changes the X position of each clone individually. |
| Per Clone Position Y | Changes the Y position of each clone individually. |
| Per Clone Position Z | Changes the Z position of each clone individually. |
| Per Clone Rotation Heading | Changes the heading rotation of each clone individually. |
| Per Clone Rotation Pitch | Changes the pitch rotation of each clone individually. |
| Per Clone Rotation Bank | Changes the bank rotation of each clone individually. |
| Per Clone Scale X | Changes the X scale of each clone individually. |
| Per Clone Scale Y | Changes the Y scale of each clone individually. |
| Per Clone Scale Z | Changes the Z scale of each clone individually. |
| Reset Per Clone Transform | . |
| Effectors | Control how the clones behave once spawned. See Effectors. | Plain Effector |
| Parameter Value Array | Used to set the parameters of the node using a float array. | Parameter Array |
