Kinect1 Skeleton
Control skeletal rigs from a Kinect 1.Updated: 15 Sep 2026
Control skeletal rigs from a Kinect 1.This node controls the Kinect Skeleton tracked from a Kinect camera sensor.
To visualise the tracked skeleton joints and their orientations, make sure to enable bounding box visualisation “BB” in the Nodegraph and this node is selected in the nodegraph.
You will need to activate the Kinect camera you want to use by going to Project > Settings > Video In / Capture > Kinect 1 and enabling it. Otherwise, it will not be initialized by Notch. This is by design, so Notch does not lock the device from the use by other software when you are not actively using it in Notch
| Use Active Skeleton | When enabled, automatically select the currently active skeleton. |
| Avatar Index | Select which Skeleton to use from the avatar index. Only functional with Use Active Skeleton is disabled. |
| Input Skeleton Scale | Scale the size of the input skeleton. |
| Smoothing | How much smoothing is applied to the output skeletons motion. |
| Derive Rotations (Don't use Kinect SDK Rotations) | Use internally calculated rotations instead of rotations from the Kinect SDK. |
| Hierarchy Root | Connect the skeleton root node to drive the rest of the skeleton from. | 3D Scene |
