Fractal Noise
Fractal Noise
Generates various fractal noises.
This node generates fractal noise patterns based on various properties, with multiple noise pattern options available.
Noise Type Select the noise function to generate noise from.
  • FBM : Generates cloudy noise using a Fractal Brownian Motion algorithm.
  • Turbulence : Generates bumpy noise using a turbulence noise algorithm.
  • Ridged : Generates curvy looking noise from an inverse of the turbulence noise algorithm.
  • Marble : Uses FBM noise to displce a sine wave pattern, creating a marbled pattern.
  • Ridged 2 : Generates curvy noise similar to Ridged mode, but with thinner lines and a stronger falloff curve.
  • Simplex FBM : Generates a smoother cloud noise using the simplex noise alorithm.
  • Worley F1 : Generates cellular noise using the F1 variant of the worley algorithm.
  • Worley F2-F1 : Generates a patterned noise using the F2 variant of the worley algorithm subtracted from the F1.
  • Worley F2+F1 : Generates a layered cellular noise by adding the F1 and F2 variants together.
  • Flow : Generates a liquidy noise by stretching and sqaushing different parts of an FBM generated noise.
  • Warped 1 : Generates an oily noise by randomly displacing a simmpler noise pattern at a low octave value.
  • Warped 2 : Generates an oily noise by randomly displacing warped noises at a medium octave.
  • Warped 3 : Generates an oily noise by randomly displacing warped noises at a high octave.
  • Warped Rotate 1 : Generates an oily noise by randomly stretching and scaling a simpler noise pattern.
Amount Change how strong the brightness of the fractal noise is.
Threshold Minimum value threshold for where the noise will be generated.
Distance Function Defines the distance function used to calculate the distance between cell points.
  • Linear :
  • Manhattan :
Marble Warp Domain-warps the noise with a sinusoidal pattern, producing banded marble-like veining.
Flow Warp Domain-warps the noise along its own flow direction, producing smearing, fluid-like detailing.
Worley Jitter How much each Voronoi cell point is jittered from its grid position, up to full randomness.
Tiling Enabled Blends the sides of the texture together, Allowing it to tile without hard borders where the noise repeats.
Time Looping Enabled Allows the fractal animation to loop within a specified time range.
Time Loop Length The time span the fractal noise will loop within.
Animation Speed The speed at which the fractal noise is animated.
Time Offset Offset the current time the fractal noise updates within. Useful for manually controlling the speed of the fractal noise.
Ridge Sharpness How sharply the ridge-shaped octaves fold back on themselves, giving crest features.
Invert Invert the brightness of the fractal noise, making the darker areas bright and the brighter areas dark.
