Sine Deformer
Sine Deformer
Deforms geometry based on a sine wave
This node deforms a mesh based on a sine wave, for creating simple wave deformation across a mesh.
  • Local :
  • World :
Sine Scale Z Scale of the sine along the Z axis.
Sine Scale Y Scale of the sine along the Y axis.
Noise Amount The amount of noise that is applied to the deformer.
Animation Speed Speed the deformer is animated at.
  • Locked To Timecode :
  • Running / Loopable :
