Sound Deformer
Deforms geometry using the waveform from an input audio sourceUpdated: 15 Sep 2026
Deforms geometry using the waveform from an input audio sourceThis node deforms a mesh using the waveform of an audio file or a live captured audio input. The waveform is processed using a set of parameters, allowing for greater control over how the sound is applied to the geometry.
| Weightmap | Add a weight map to determine where the deformer is more or less effective. |
| Apply Mode |
Choose whether the deformer applies to the individual vertices or the mesh chunks.
| Transform Space |
Choose which transform space the deformer uses for deformation. Does not affect falloffs.
| Blend Amount | Global override for how much the deformer affects the mesh. |
| Time Mode |
How the deformer updates with relation to the timecode.
| Sound | Sound file used to drive the effect. |
| Channel | Which audio channel is used. |
| Frequency Band | Sets the Band EQ to one of the given presets. |
| Band EQ | Selects and weights the frequency bands to be used from the sound file. |
| Time Offset | Offset the time the clones are modified from the time the waveform is at. |
| Threshold | Changes the threshold for what counts toward the effect. |
| Attack | Controls the initial time between the current values to the peak. |
| Decay | Controls the time between the peak to the sustain level. |
| Min Value | Acts as a minimum threshold for extracting a range of values from the waveform. |
| Max Value | Acts as a maximum threshold for extracting a range of values from the waveform. |
| Clamp | A maximum value which values will be clamped if they go above. |
| Spikiness | Accentuates peaks in the waveform so they are sharper. |
| Scale | How much the output values are scaled. |
| Smoothness | How much smoothing is applied between differing values. |
| Mapping Mode |
How the audio data is mapped onto the mesh: Planar projects the wavefront along a plane, Radial maps it ballistically from a centre, UV uses the mesh’s texture coordinates.
| FFT Sample Scale | Scale the size of the waveform as it is applied. |
| Noise | The amount of noise that is applied to the deformer. |
| Max Displacement | Maximum distance the deformer can displace the mesh. |
| Displacement Direction |
Change the direction the deformer displaces the mesh.
| Waveform | Visualises the waveform of of the sound. |
| Falloff Mode |
| Falloff Direction |
| Falloff Easing Mode |
| Sound | Use the waveform from a given Play Sound or Sound Capture node. | Sound Loader |
| Generated Weightmap | Add a weightmap to vary the strength of the deformer across the surface. | Generate Weightmap |
