Spline From Nulls
Spline From Nulls
Add a spline to the scene.
This node defines a spline in 3D space from a number of control points. Control points are specified by linking Null nodes to the Spline Nodes input, with the position of each Null used as the position of the control point; the rotation of the Null is used to control the tangent direction of the spline at the control point, and the z scale controls the magnitude of the spline. The ordering of the control points is defined by the vertical ordering of the nodes.
Splines may also be imported from 3D packages as part of 3D Scenes.
Splines may be used in conjunction with Spline Followers to allow geometry or transforms to follow the path of a spline. Splines may also be used with Particle Spline Emitters to emit particles from splines, or connected to Spline Deformers to deform 3D objects using splines, and numerous other uses.
This node outputs a spline which can be input into other nodes which use splines to generate new effects, such as the Spline Extruder or the Particle Spline Emitter.
Spline Time Mode Controls how the spline is evaluated by spline followers.
  • Knots : followers take the same amount of time to move between each control point on the spline.
  • Length : the time followers take to move between each control point is normalised by the distance along the spline, so the follower will appear to move at a constant rate.
Normalise Spline Time Normalises the Normalises the spline times between 0 and 1.
Looping Control whether the spline animation loops.
Tangents Control how the spline tangents are generated for the spline
Tangent Smoothness Controls the auto-smoothing of the tangents, and how much smoothing is applied
Control how the spline is visualised in the scene for debugging purposes.
Show Spline Select which properties of the spline are visible.
  • Spline + Nulls : Both the control point nulls and the spline will be visible.
  • Spline : Only the spline will be visible.
  • Nulls : Only the nulls will be visible.
  • Off : Neither the splines nor the nulls will be visible.
Spline NodesThe control point nodes for the spline. A transform array can also be connected to control the spline generation.Null
Colour SourceAffect the colour of the dither.Colour Ramp
