Noise Deformer
Noise Deformer
Deforms geometry using noise
This node displaces the vertices of a mesh using noise, fractal noise, a grid, and/or an input image or a video node.
  • Local :
  • World :
Fractal Noise Amount The amount of fractal noise that is applied to the deformer.
Fractal Noise Scale The scale of the fractal noise that is applied to the deformer.
Fractal Noise Threshold The threshold for the fractal noise, below which the no deformation will be applied
Octaves How many times the noise generation is iterated.
Grid Amount How much the deformer uses a grid to displace the mesh.
Noise Amount The amount of noise that is applied to the deformer.
Animation Speed Speed the deformer is animated at.
  • Locked To Timecode :
  • Running / Loopable :
Grid NodeA node used to control the transformation values of the grid attribute.Null Node
